Hi Ragic Team,
Does we have any script for re-calculation and re-sync data after saved entry like postworkflow action.
Indeed, I see this very needed action when we have to work within updating entries many times.
Are you referring to formulas recalculation and link & load sync? If so, yes, please refer to our documentation:
Thanks Amy,
I found the instruction for using installed sheet scoped javascript for adding recalculate button here https://www.ragic.com/intl/en/doc-kb/217/Adding-a-button-to-formula-recalculate-all-records-in-a-sheet.
It’s very nice and useful but can you change it to post-workflow? It’s can automatically work after save the entry.
It’s supported by post-workflow. You may forward our javascript documentation to your developers to refer to.
