How can I save the pdf paper size settings to landscape and letter so they are the default settings?
May I know if you’re referring to the “Download as PDF” feature? If that’s the case, recently we’ve applied an update so that the system will remember your last setting.
But it only remembers by individual record, not as a global setting for all records on a sheet?
The settings will be applied to all records within the same sheet.
It does not appear to work. Where is the setting?
As stated in the previous reply, it will remember your last settings of download as PDF.
