I’m a brand new Ragic user (signed up about an hour ago), experienced spreadsheet user. Having trouble with IF. To keep things as simple as possible:
I have a subtable that starts in A11 (headings are in row 11).
B11 is the heading for a selection field with three possible values: None, Minimal, and Extensive.
If I set D11 to free text and use the formula B11
, when I change the value in B12, the value in D12 updates just as expected, to match the value in B12.
If I set D11 to free text and use the formula B11=='Minimal'
, when I first look at the record, if the value of B12 is not Minimal, the value of D12 reads false. If I change the value of B12 to Minimal, the value of D12 changes to true. If I now change the value of B12 to None or Extensive (i.e., not Minimal), the value of D12 is empty (not false).
If I set the value of B12 to None, then edit the design to set D11 to numeric with the formula IF(B11=='Minimal',1,0)
, after I apply the formula, save and exit, and return to the form view, D12 now reads 0.0. If I change the value of B12 to Minimal, D12 remains 0.0.
I’m really confused at this point. Would somebody kindly tell me what I’m doing wrong?
