This report could be useful, however we need the ability to scroll the timeline. There is currently no horizontal scroll which hampers its use.
A fixed header or option to limit the number of horizontal rows would also be useful.
Thanks
Shane
Thanks
Shane
Hi Shane,
As I’m not quite sure about what you meant, do you mind sharing us with some screenshots and further information for us to refer to?
Thanks!
Hi Amy,
It’s a hard one to screenshot - if you look in my account their is a single report called Gantt.
Try viewing the Gantt grid for the month of March 2018 or beyond without using additional filtering.
I’d expect to be able to scroll across the months and years in this report for it to be of use to me.
There are also too many vertical items for the amount of data I’m look into to display.
Thanks
Shane
Hi Shane,
Do you mind sending us a short video of this (with full flow of navigating to the report, entering filter query, and elaborating your needs) by emailing to support@ragic.com so I can understand it better?
Thanks!
