As the formula gets more complicated, it is hard to follow as the field is too small. I suggest making it bigger or having a large are pop up. Thx.
Thank you, we will consider some options for displaying and editing long formulas. Having a pop-up window seems like one of the way to go.
It looks like the field expands on its own as I type.
This works for me.
