Hello!
I embed one of my sheets into a Website but when I try to save the record it keeps forever loading and nothing changes. However since that record has an active review field I got the notification as success.
Using Chrome.Ver 76.0.38
Could it be that Im doing test with the same user? Submitting user and reviewer are the same .
Thanks!
Would you please submit a ticket through “Need Help” at upper right corner in your database > “Support Ticket”, fill up the form with below information for us to check for you?
(Embedded) Sheet url
Steps to reproduce the issue
If we can test in your database by following your steps
