Hallo
is there a possibility to stretch to fit images to the specific size set for the field ?
This would be a great improvement in the look of the forms.
thanks
Luca
Hallo
thanks
Luca
OK, that sounds like a pretty good idea. I will submit this internally to our development team and see if we can add this as an option.
Hi Luca,
In your case, when the image is resize to fit the container, the width and height ratio may be changed and the image distorted. Is this something that you expect to happen in your use case?
