Hi
I really like how duplicated sheets are connected and update automatically when changes are made on either sheet regardless of how different the design is.
If I have two sheets already set up with the same data set, can I make them a ‘duplicated’ sheet of each other? Or is there some way to connect two sheets so that changes on either of the sheets are reflected on the other? (i.e. changes to shared info sheet 1 are shown on sheet 2, and vice versa)
