I have a subtable that I want to add email address to in the box to the right of DofE Ass.
Is it possible to have more than 9 fields in a sub table?
You can exit the link manger, save the sheet design, and then re-open the link manger. Then, you should be able to see extra spaces.
I’m afraid that doesn’t work. The original links have been set up for months. i am wanting to add one more but can’t seem to move the focus of the screen to allow more of the grid to be shown.
Fixed: I created a dummy field before going into the link manager which zoomed it all out a bit and then overwrote it
Hi Andy,
In this case, it’s suggested to created the fields you need on the sheet first, then set up linking lines through link manager.
Best,
