I was trying out all the reports but no joy. I am looking to put in some criteria and get a matching list. Like a field saying ok and get a list of records with the field with ok in it.
Thank you.emphasized text
You could save frequent search like the field value is ok as a personal view or shared view.
That’s brilliant I never even saw the views. Could I ask one other thing. In excel you can reference a cell in another sheet, like vsum etc can that be done here in Ragic. Thank you very much.
Currently, formulas only can refer to the field on the same sheet and same entry. Which referring fields on another entry or another sheet is not supported, It need custom scripting to achieve this.
Or you may have to get the values on another sheet to the sheet which formula assigned through linking tools, you can reach out to the manual by clicking this link.
