Like Ragic will automatically open a record when it is the only result in a top global search can the same logic be applied to drop-down menus?
The primary objective of a drop-down is the link and load selection of one record, and very often when you search the drop-down list it comes back with one result which you then still need to click. If Ragic only finds one record I suggest it selects that record.
Thanks
