I have some real estate property records, listing records that I link and load from some property “unit” records…
At the moment I cannot keep the link and load synced, as I would not want to update the “no longer listed records” as well…
I have chosen to then manually sync (one Listing record at a time) with the use of an action button,… every time I update a property unit record…
Funnily this works fine,
However, if I had this ability, I could make updates to a “property unit” record and have the changes automatically updated on an available listing, without having to first open the listing form, and then click sync after the changes are made on the property unit…
You can see a related post here…
Question regarding dynamic filters for link & load! - Ragic Community
Thanks guys for listening, and I hope you like the suggestion!
Kane
