I would like to be able to get automatically the Longitude in one field and the Latitude in another after entering an “address” in a separate field. What formula should I use?
I checkout Addresses and Ragic’s google map features first, but it does not specify how to do this, only says you can enter an address using the map, or enter it as either a regular written street address or as a Longitudinal/Latitudinal value, and that you can also choose to have the address appear as a MAP.
Thanks in advance!
Kane
