Is it possible to have more columns than just A through U? 20 columns isn’t quite enough for my application.
Thanks!
Thanks!
Once you save the design, exit the design mode, and re-access the design mode, you’ll have more columns and rows.
Note: if you’re on the listing page, it’s not recommended to have that many fields. Otherwise, it may take a while to load every time you access the sheet.
I have the same problem but exiting and re-entering design mode makes no difference unfortunately.
If your listing page is meeting the limit, please add a new field near by column “T” after saving and re-access the design mode, it would be extended.
