Hello,
What is the trick to adding a column to an existing table? I have a table set up based on an import from excel and wish to add a new column at column B. Right clicking on the B only gives me the option to delete the column.
Thanks,
Brett
Hello,
Thanks,
Brett
Hi Brett,
If you’re in the design mode, you can focus on the column you would like to create a field and type the field name directly. You may refer to this document for further explanation.
Are you trying to replace this column with a different one? With different information?
